Inventor Forum
Rope and Pulley Animation
4 REPLIES 4
volkan
2926 Views, 4 Replies
I want to make a simple rope and pulley animation with Inventor. I tried adaptivity and driving the constraint but failed. This what I am trying to do;
http://www.youtube.com/watch?v=p44iVsLeVFU
Anybody have an idea on that?
I attach the pulley. Don't know if it helps.
Volkan
Volkan ARI
4 REPLIES 4
Paul-Mason
in reply to: volkan
Here is an OLD (2009) discussion to the same question.
http://forums.autodesk.com/t5/inventor-general-discussion/pulley-animation/m-p/2418529/highlight/tru...
And an even older discussion
http://forums.autodesk.com/t5/inventor-general-discussion/pulley-design-and-animation/m-p/2144782/hi...
I found quite a few using "Rope and Pulley Animation" In a general community search
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
JDMather
in reply to: volkan
Not exactly the same problem - but clever solution that could be adapted.
http://forums.autodesk.com/t5/inventor-general-discussion/animate-belt-and-tensioner-pulley/td-p/537...
wimann
in reply to: volkan
I was unable to open your pulley since you're in 2015. Funny, I'll be switching to 2015 on Monday, so close but no cigar.
Nevertheless, I created a part file that simulates the rope passing over a pulley. Are you familiar with Inventor Studio? I highly recommend it in this case. I usually would animate something like this with a rectangular pattern on a curve however, since this is rope, it has to use a coil. There are a few things to keep in mind since that is the case: 1) Coils can't follow paths 2) A bend has to be used 3) Coils slow down your machine.
I started trying to write out some of the specifics of the part I made and why I did some of the things the way that I did them, but that started to become a jumbled mess. It'll be easier to let you crack open the part and dig around. You can change everything through user parameters in the parameters menu. I also set up a form that can be used to manipulate the model. You get to it by going to the manage tab on your ribbon, then to the iLogic section, select iLogic Browser, select the Forms tab and click Driver.
Let me know if you have any questions. I'm certain there may be one or two.
Oh and feel free to ignore my "pulley" lol
EDIT: Created second rope part file that has the option of changing the number of strands in the coil. The one I originally did had 3. This one you can change from 2 to anything above 2. I'm sure there is a failure point but I haven't ventured far enough to find it. The parameter is NoStrands and is only accessed through the parameters menu.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
volkan
in reply to: wimann
Good morning everybody,
Thank you so much for all your help. I'll try them in order and put the result back here.
Cheers,
Volkan
Volkan ARI
