Well yeah I suspect that too.. but we're an ADN member ourselves so if we
need consulting we're probably using that connection. It's just that we are
not sure if this is a good idea to produce an application for this specific
usage.
The problem is; We identified the majority of totally different
configurations... it ended up to be a rather high number, but within a
reasonable range (just barely). But we're not sure if we should multiply
this number of configurations with all the 'detail-configurations'.
As I look at it now, we would need to produce different Inventor models
depending on the detail-solutions... since parts are adeptively connected
and the I-mates/workplanes and such need to be defined differently for
different ways of making joins (technical details).
If this is really the case (as I suspect) the whole application is
economically out of range, the productioncost of it would make the
product -way- too expensive for anyone to be interested in buying it from
us... not to mention the time and efford it would take out of our
organisation.
> so.. you suggest VB front-end (as we do) but we also would need something
like VB 'internally', not just to redefine adaptive parameters but to
actually do assignments such as 'mate this-and-that end of so-and-so part
with a certain workplane' (as we would define workplane selection through
VB/form).
I hear VB possibilities in Inventor are there, but it's not this advanced
yet.. also keeping in mind that the models we would need to use end up to be
extremely complex (the test-model I produced took lots of work as to how to
arrange the assembly structure, sub-assemblies etc.. it is a very sensitive
thing).
Love to hear any input/suggestions 😉 Vincent
"Gary R Smith (Autodesk)"
> I suspect there would be quite a few here who would love to sell you
> consulting work to accomplish this.
> The trick would be to identify a majority of the totally different
> configurations up front, build a VB/form-based front-end (to select the
> basic approach) and then put the various pieces needed by Inventor "under"
> that.
> Building a single assembly and "hiding" all the stuff you didn't need
would
> not be the best (or most performant) way to approach the problem.
