Glad to hear it Paul. BTW, there is a tutorial explaining the process for
this at www.b2-design.biz/tuts.html
______________________________
Bill Bogan
Product Designer - Autodesk Inventor
Manufacturing Solutions Division
Autodesk, Inc
"Paul Bartlett" wrote in message
news:5046458@discussion.autodesk.com...
Thank You Bill, It's perfect. You made my day.
I have a lot of different roof materials that I can now alter to be usable
in Inventor.
"Bill Bogan" wrote in message
news:5046303@discussion.autodesk.com...
Paul,
The DPI needs to be reduced to 18dpi. for the image.
In the attached image the DPI for your shingle image is set to 18dpi (made
from the 72 dpi image).
I then scaled the texture to 200% to get what I think looks good.
Notice the part I put it on... 18'0" x 40'0"
I also rendered it so you could see what it looks like. Ignore the glare
that's because I just applied the texture to the default and didn't mess
with the surface style settings, just the image dpi.
Since I run my 'puter @ 1600
x1200 I also reduced the screencap image by 50%
so I could attach it.
I will post the 18dpi image after this post. BTW, if you simply reduce the
DPI the image size (in inches) changes, but not the filesize. It stayed at
192kb.
Bill Bogan
Autodesk, Inc
news:5045931@discussion.autodesk.com...
wrote in message news:504591
can you post a screenshot of your problem?
