Inventor Forum
Roof again :)
7 REPLIES 7
Message 1 of 8
majusmiles
574 Views, 7 Replies
Roof again :)
With johnsonshiue and wh help i made my roof.
It will work, i made something like this before, different software and long time ago
So THANK YOU, and i just have one question.
In this roof: one spline, one template x8, simmetrical roof
If i want to make the roof with of centre top hole, everyting else stays the same, non symmetrical.
Do i have to make 8 different splines to make 8 different templates or there is a smart and nice way?
7 REPLIES 7
Message 2 of 8
Cadmanto
in reply to: majusmiles
Can you post your part to take a look at?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
majusmiles
in reply to: Cadmanto
there are files
Message 4 of 8
Cadmanto
I am looking at your model.  The first question I have is, in your assembly model you have 8 sides, yet in your picture it shows 6 sides.  Which one do you really want?  That matters because it will affect the width of each panel.
Regardless, this is what I came up with.  See the attached models.
You might also want to figure out how to pattern the panels in the part instead of creating an assembly.
Best Regards,
Scott McFadden
Message 5 of 8
majusmiles
so, 8 sides one, 6 sides is old one
Mariusz Milewski
Message 6 of 8
JDMather
I am confused about the design intent.
Something like this?
Message 7 of 8
majusmiles
in reply to: JDMather
HI , Thank You for the answer, and i am sorry for not precise question.
Amount of sides and shape of top  hole doesn't matter (bdw i need to find time to lern i find out how Cadmanto made it )
All that samples are symmetric roofs, but what if the top hole is not in center of roof and width an hight of roof stay the same
Message 8 of 8
Cadmanto
All I did was take your part file, shrink the smaller hex sketch to be smaller.  Meaning a greater (larger dimension spacing size from large hex) distance from the large hex.
That made the top portion of the surface come to more of a point in the top middle.
Then in the assembly I just created an assembly cut for the hole.
Hope this makes sense.
Best Regards,
Scott McFadden
