Howdy all,
I was just toying with a C3 x 4.1 x 31'2-1/2" LG piece of channel from content center. What I want to do is roll it into a complete circle, radius given on 2d drawing is 4'7-25/32r.
I tried putting a line the length of the channel, didnt work. Tried a short line in the center. Or made the rad on the center. Therefore I am not sure how to put this rad and roll entire part.
File attached to see what I did... And failed lol
Thanks! =]
Take a copy of the profile sketch Start a new part or do this in the existing ...
In the main sketch ..make a line 4'7-25/32r. up ...change it to centerline and then revolve the profile ... I've attached a part to show it
or are you looking for something to flat pattern?
A simple sketch of the given dimensions demonstrate that they aren't even close?
Ok .... mine should show you what I was saying ..and how it was done (however I didn't fully constraint it all ...but rather quick example)
Of course it is a good idea to always check against the problem statement.
I worked my way through part of uni as an AE for a VAR.
Every time I would go out on sales call I would do my dog-and-pony show and they would politely watch.
Then when I finished they would always throw some knarly drawing in front of me and say, "Now draw this."
Virtually ever single time I would get half way through I realize I must of made a mistake. Wait a minute.
I didn't make a mistake - the drawing was wrong. This happened every single time.
Made the sale, every single time.
You may have been helped already but here is what I do..
I don't use content center parts I have my own.
This may help you when you need to roll channel the excel has all channel sizes just use the drop down and select size..
In the fx you will see lenght to change that..
