Inventor General Discussion
Valued Contributor
ScottSwens
Message 1 of 7 (183 Views)
Roller Ghain - Double pitch
183 Views, 6 Replies
07-02-2013 09:59 AM
I am using the Roller Cain generator to design a chain drive. I wish to use ASME B29.3 Double-Pitch Power Transmission Roller Chain #2050. The generator says the pitch is 1.125.
If I look up the same chain from US Tsubaki, they are giving me a pitch of 1.250.
Whos is correct?
I am using Inventor 2013.
thanks
mrattray
Message 2 of 7 (173 Views)
Re: Roller Ghain - Double pitch
07-02-2013 10:44 AM in reply to: ScottSwens
I use #2050 chain daily. Pitch is 1.250".
In fact, here is my purchase specs out of my ERP system for 2052 chain in case it helps you:
PP-CH-2052-D3-05
BLM CHAIN #2052-D3 @ 5" CENTERS
>Carrier Roller Chain
>Double pitch roller chain with oversize rollers
>D3 attachments on 5" centers
> 1.250" pitch
> Roller dia .750 /19.05mm
> Roller width .375 / 9.525mm
> Pin dia .200 / 5.08mm
> Plate height .594" / 15.0876mm
> Plate thickness 0.079"
> Maxium Allowable loads 970 LBS
> Average Ultimate strength 6,620 LBS
> Tensile strength 6100 LBS
Mike (not Matt) Rattray
blair
Message 3 of 7 (172 Views)
I would go with the data from the chain supplier that you will be using.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
mrattray
Message 4 of 7 (167 Views)
07-02-2013 10:46 AM in reply to: ScottSwens
In fact, I'm curious where they get 1.125 from, because 2040 is 1.0"...
Valued Contributor
ScottSwens
Message 5 of 7 (164 Views)
07-02-2013 10:47 AM in reply to: mrattray
that makes two of us.
*Pro
jletcher
Message 6 of 7 (147 Views)
Re: Roller Again - Double pitch
07-02-2013 11:17 AM in reply to: ScottSwens
That is why I don't use it or content center parts.
 Burn me one time never again cost me lots...
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
dan_inv09
Message 7 of 7 (136 Views)
07-02-2013 11:39 AM in reply to: jletcher
Ditto
