Inventor General Discussion
Active Contributor
GarySchmitz3154
Message 1 of 6 (140 Views)
Rip not centered
140 Views, 5 Replies
08-19-2014 08:00 AM
I am ripping a sheet metal ring and the rip is not centered on the plane that I used for the cutting plane. it is not consistantly off center. The off-centeredness is progressive to the width of the rip. The wider the rip the further off center. I wish to rip the ring with a width 7' 8 1/4" centered on the xz plane. I use the rip feature alot and this is the first I discovered this. Attached is the file. the question is am I doing anything wrong or is normal
Best Regards
Gary
Best Regards
Gary Schmitz
Dell Precision M3800
Core I7, 2.3GHZ, 16G Ram, Quadro K1100M 24In Monitor
Product Design Suite Standard 2014
3D Connexions Wireless
ProNest 2015
Gary,
This is a great catch! There is something wrong here. It seems there is a floating tolerance corresponding to the model size. When the part gets bigger, the tolerance becomes bigger, which is wrong. For this particular model, the difference starts becoming noticeable when the gap exceeds 1in. I am forwarding it to development for further review.
Many thanks!
Distinguished Mentor
ccarreiras
Message 2 of 6 (132 Views)
Re: Rip not centered
08-19-2014 08:09 AM in reply to: GarySchmitz3154
HI!
In my case, i opened the file,  all seems cetered...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Active Contributor
GarySchmitz3154
Message 3 of 6 (121 Views)
08-19-2014 08:34 AM in reply to: ccarreiras
when I measure rom the point on the outer surface to the xz plane the left side reads 37.729 ant the corresponding right side point measures 34.445
Best Regards
Gary Schmitz
ProNest 2015
wh
Message 4 of 6 (89 Views)
08-19-2014 03:43 PM in reply to: GarySchmitz3154
Interesting observation, Gary. I could reproduce it.
Walter
Employee
johnsonshiue
Message 5 of 6 (82 Views)
08-19-2014 03:55 PM in reply to: GarySchmitz3154
Gary,
Many thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
Active Contributor
GarySchmitz3154
Message 6 of 6 (40 Views)
08-22-2014 11:17 AM in reply to: johnsonshiue
Wow
With that being said, I will just have to use a different method of removing that much stock instead of ripping.
Best Regards
Gary Schmitz
ProNest 2015
