Attach your file here.
Are you using sheet metal tools to create the part or are you converting a standard part to sheet metal?
You must click the Sheet Metal Styles and set the Thickness variable equal to the actual thickness of the part.
1. As a beginner - use sheet metal tools to create sheet metal parts (one circle and Contour Flange?).
2. You never stated setting the Thickness variable.
3. You didn't attach your file here so that someone could show a screenshot of YOUR file with the technique to set the Thickenss correctly.
Attach your ipt file here and someone will show you how to solve the problem.
Evening
I'm new to inventor, but trained in Autocad.
Just wondering it's possible to 1) rip a Ellipse Loft? 2) create a flat pattern?
I've created the attached part via sheet metal (mm). The thickness is 1mm.
Any help would be much appreicated.
Kind regards
Hi Rydson
Thank you for getting back to me.
I can't seem to open the file because I'm on an older verison of inventor. I get the attached errror message
