Does anyone use RiCAD-3D 3.2?
I have Inventor 2013 installed and can't export encloure models from RiCAD to Inventor format.
I turned on Inventor 2013 before using RiCAD-3D.
RiCAD-3D gives an error message of "Error occurred during export (CAD system should be started up.)!"
Your helps are much appreciated.
Most likely you will need to export from RiCad to a neuatral format such as STEP or IGES and then import the file into Inventor.
There is no problems when outputing STP, even DWG files.
Still cannot figure it out.
I have also tried on other pc which has Inventor 2014 installed and the exporting Inventor models are just fine.
Try a different User account on the PC that you have been having the problems with.
