Inventor Forum
Ribbon menu justified to right
13 REPLIES 13
Message 1 of 14
NeilClasby75
904 Views, 13 Replies
Hi
I have switched computers from my laptop to my workstation.  My laptop has an Nvidia card FX2500M, and my workstation has an ATI Fire V5600.
I work with the ribbon minimised to tabs.  On my laptop, when I click a tab the ribbon opens directly below the tab (i.e. justified to the left of the screen); but on my workstation, the ribbon opens below the tab but justified to the right of the screen.  This means I have to move the cursor back and forth across the screen.
Is there a Reg setting to change the justified back to the left of the screen?
When the ribbon minimise is on other settings (e.g. minimise to panel tiles) the ribbon is justified to the left side of the screen.
Personally, I think its an easter egg from one of those wierd left handed people - like my wife!!! 🙂
Inventor Pro 2012 with SP1.
Cheers, Neil.
13 REPLIES 13
Message 2 of 14
mercerc
in reply to: NeilClasby75
To see where the justification was set to. In the ribbon menu at the end in a gray area (no tabs) or anywhere in the ribbon. RMB and select the Ribbon Appearence and see that it set to Normal and Docking Position, TOP. Check that before (if you haven't)  we look at the registry.
Charlie M
Inventor Product Support Specialist
Message 3 of 14
NeilClasby75
in reply to: mercerc
Yes, I checked and it is set to 'top'.
Message 4 of 14
NeilClasby75
Hi
Have you got any suggestions on the registry to try?
I have no issues with editing the registry.  I did this before when I suddenly had the original interface in 2012, and had to switch it to the ribbon.
CHeers, Neil.
Message 5 of 14
NeilClasby75
I have just updated my laptop to Windows 7.  I have a Nvidia Quadro 2800M card.
I have been using this setup for a few days with no problem, but I was just changing the pre-highlight settings (turn off) and Optimized selection (changed time to 1.0 sec).  Suddenly my minimised ribbon is now justified to the right of the screen again (like I had on my main workstation - also Windows 7, but with FireGL card).
I have tried putting settings back but menu is still justified to right.
This is a real problem as it slows my work flow down considerably.
You help would be greatly appreciated.
Regards, Neil.
Message 6 of 14
NeilClasby75
Here is a PDF screenshot.
Message 7 of 14
NeilClasby75
Anybody got a solution?
Message 8 of 14
blair
Try cycling the Menu around, Top, Left, Right and back to Top and see if that fixes it.
Never seen a Menu with RH justification.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 9 of 14
NeilClasby75
in reply to: blair
Hi
Just tried cycling the options.  I did this with the ribbon in each minimise option, then each location, but it didn't sort it.
I also noticed the reset to default, but that didn't sort it either.
Help!
Message 10 of 14
NeilClasby75
Any more suggestions from Autodesk?
Maybe some Registry values to tweak?
Cheers, Neil.
Message 11 of 14
NeilClasby75
Hi
I still have this problem.  I have just loaded 2013 and it is still the same.
This is really annoying.
Any suggestions for rectify?
Regards, Neil.
Message 12 of 14
Scottu2
I had this problem too.  The menu ribbon or pull-down flyouts are right justified.  This problem is not caused by Autodesk products, but rather Windows 10 update.  In WIN10 there is an option to set the context menus from left-landed to right-handed when using a tablet.  I don't know why WIN10 update thought my desktop was a tablet with touch screen ability.
Here is the solution:
Open the Device Manager - Human Interface Devices -
Enable Splashtop (r-click) then restart windows (doing this makes the Tablet PC control panel available)
Enter "tablet PC" in the Cortana ask me anything box (not the same as Tablet Mode)
Click the Other tab and click the radio button Lef-Handed
If you experience Autocad hanging or freezing when pressing the F8, F9, F10 or F11 during a move command then Disable the Splashtop Virtual Hid.
I hope this works for you.
Message 13 of 14
Scottu2
in reply to: Scottu2
Hi guys,
The pulldown menus (Context Menu) flyout to Left instead of Right.
I had this issue on an Autocad station and it did not have the Splashtop items in the device manager.
I did find this solution for a workaround:
Press Windows logo key+R (Run dialog box).
Enter the following text to activate the Tablet PC Settings config dialog box.
shell:::{80F3F1D5-FECA-45F3-BC32-752C152E456E}
Select the OTHER tab and change the radio button to LEFT Handed.
Close the box.
Hope this helps.  🙂
Message 14 of 14
janders4
This does work even with the 2018 version. It would be nice if Autodesk would place an option in the preferences to fix this. It's not easy to switch back and forth if you use your touch screen for other purposes. A restart is not required. the menu will switch back and forth as you switch the setting in the control panel.
