Hey there!
The ribbon seems to break sometimes in Inventor 2015. Check the picture - I guess it's a bug
Best regards
Yannick Nielsen
Solved by JDMather. Go to Solution.
Addition: In my case it seems to happen only to the 3D Model Ribbon
Sheet Metal and the others are perfectly fine.
I updated the nVidia driver to version 320.00, may 27th, 2014
I haven't see that in 2015, but I have seen the same thing happen in earlier releases in some of our older labs.
I used to tell my students to restart Inventor till one of them discovered that clicking here 4 times (slowly) seems to get the Ribbon back to usability. Happened to me a couple of years ago while taking the timed certification exam. Sure glad I knew this trick.
That did, indeed, seem to work here as well.
I haven't seen it happen before, though. Only in the 2015 version.
As I recall (I've seen it three times since we installed 2015), it has happened every time I've double clicked a part in the assembly environment.
It persists until I either restart inventor or do that trick.
The thing is, though. It doesn't happen every time I double click in the assembly. Only sometimes
Timed, schmimed.
Based on how long it took me to finish the certification exam, you should have been able to restart Inventor 20 or 30 times and still finish the test with at least 2 hours and 45 minutes to spare. :lol:
Rusty
