The Replace function is not directly accessible on the Ribbon, you need to click on Component first, then you can click on Replace (see attachment).
Why is this changed (not sure if it has been like this in IV2014 as we switched from IV2013 to IV2015) and is there a way that I can set up my own Ribbon? As for now the Ribbon uses only like 60-70% of my screen width, so there is plenty of room left to make more buttons directly accessible.
Thanks in advance,
Dominiek
Solved by WHolzwarth. Go to Solution.
Hi Dominkien,
yes, there are some changes in the ribbon in the last releases.
You can customize ribbon adding your custom panel user commands, you can recall with alias shortcuts your more used command , you can add commands in the contestual menu/marking menu with right click.
Just Tools>Customize
Admaiora
Yes, I know that's possible, but then the button's are located under Custom Commands and for example for Replace, not under Component.
Then it's almost better to hide all the panels, and make a large Custom Commands panel with all the necessary buttons....
I think it should be possible to expand a panel, that should be very easy for Autodesk to implement, right?
No big deal. Simply right-click to a ribbon icon.
You can change:
- Icon size
- With or without text
- Ungroup from dropdown menu
- Move to main toolbar
Walter
Walter Holzwarth
Well, it was what I needed, but every time I start Inventor, it's back to the previous configuration, so I need to do this every time I start Inventor.
Can I do something so I don't need to do this every time anymore?
Thanks in advance,
Dominiek
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I have admin rights.
I just tried with running as admin, made my changes, closed Inventor, restarted running as admin, but they are gone again 😞
Anything else I can try?
Niels van der Veer
The Netherlands
UAC is turned off.
I have Panda Endpoint Protection but I'm not able to turn it off.
Niels van der Veer
The Netherlands
Ribbon customizations are not stored in the registry. On my computer (Win 7), they are stored in C:\Users\username\AppData\Roaming\Autodesk\Inventor 2015\InventorCustomization.xml. Since this is under your user profile, it's not at all obvious why Inventor is not able to write to that file, but that's where you need to check.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2015 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Well, then it's going to be a tedious task finding a solution...
Seeing as older topics also never got it resolved, i can only give you some suggestions on things to try.
These will probably take a lot of time and aren't a guarantee on fixing it.
Anyway:
1. try creating a new user profile and see if the ribbon customization sticks on that.
2. uninstall the antivirus and see if that helps.
3. if that doesn't, reinstall inventor without anti-virus (and UAC off, ofcourse.)
4. last resort; completely reinstall your system.
#4 isn't worth it though, i'd open a support ticket with autodesk if #3 doesn't resolve the problem and see if they can help.
---edit---
@SBix26 I didn't know about that, nice one!
Let's just hope it has something to do with that then, you'd think having admin rights would let you write to such a basic location...
Niels van der Veer
The Netherlands
I looked at that file, Sam, and it is saved every time I close Inventor. So it is accessible.
I looked through that file and see the following info:
<Ribbon>
<InvRibbonUICustomizationInventorLangID="2067"InventorVersion="19.0"OSVersion="Microsoft Windows NT 6.1.7601 Service Pack 1"RevID="2">
<RibbonStates>
<RibbonRibbonID="Assembly">
<RibbonControlMinimizeMode="None"MinimizeRule="CycleThroughAll"ShowPanelTitleInHorizontalRibbon="True"ShowPanelTitleInVerticalRibbon="True">
<Tabs>
<TabCookie="Tab=id_TabAssemble"IsActive="True"IsVisible="True">
<PanelCookie="Panel=id_PanelA_AssembleComponent"FloatingGroup="0"FloatingLocationX="0"FloatingLocationY="0"FloatingOrder="0"FloatingOrientation="Vertical"IsFloating="False"IsVisible="True"/>
Scrolling a bit further down I see:
<Ribbon>
<InvExpandedFlyouts>
<RibbonRibbonID="Part"/>
<RibbonRibbonID="Assembly"/>
<RibbonRibbonID="Drawing"/>
<RibbonRibbonID="Presentation"/>
<RibbonRibbonID="iFeatures"/>
<RibbonRibbonID="UnknownDocument"/>
<RibbonRibbonID="ZeroDoc"/>
</InvExpandedFlyouts>
I think I need to see something here. Can anyone try to move a button from the expanded panel to the main panel (and close Inventor) and search where it is mentioned in this file?
Thanks in advance.
PS: to Niels, I'll wait a bit with your options as they take a lot of time 🙂 Maybe I can manually adjust that file.
In mine, I have a number of entries under InvSlideout (see image below from XMLNotepad), which I believe correspond to items I have moved from dropdown panels to the main group.
Sam B
Hmm. My customization settings are stored in a different place:
C:\Users\Username\AppData\Local\Autodesk\Inventor 2015\Preferences
They are stored this way:
Tools -> Customize -> Export -> Choose Filename
My settings are not lost with a re-start. If lost after restart, they can be brought back again:
Tools -> Customize -> Import -> Same Filename as above.
Walter
Walter Holzwarth
I tried that Sam, but can't be sure about the correct inputs. I tried the following:
<InvSlideoutRibbonID="Assembly">
<InvMovedItemSourcePanelID="id_PanelA_AssembleComponent"SourceTabID="id_TabAssemble">AssemblyReplaceCmd</InvMovedItem>
But that didn't help.
Like I say, I'm not sure about the inputs, if they are correct:
- id_PanelA_AssembleComponent
- id_TabAssemble
- AssemblyReplaceCmd
They strange thing is, I moved the following items (in Inventor), and they are still there (so some work, others (Replace, ...) not....):
<InvMovedItemSourcePanelID="id_PanelA_DesignFrame"SourceTabID="id_TabDesign">AFG_ProfileInfo</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_DesignFrame"SourceTabID="id_TabDesign">AFG_RebuildProfile</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_DesignFrame"SourceTabID="id_TabDesign">AFG_CMD_Refresh</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_DesignFrame"SourceTabID="id_TabDesign">FDBeamPlateSplit</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_2DSketchFormat"SourceTabID="id_TabSketch">SketchLineTypeProperty</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_2DSketchFormat"SourceTabID="id_TabSketch">SketchLineColorProperty</InvMovedItem>
<InvMovedItemSourcePanelID="id_PanelA_2DSketchFormat"SourceTabID="id_TabSketch">SketchLineWeightProperty</InvMovedItem>
