Inventor Forum
revolved section or removed section
5 REPLIES 5
2213 Views, 5 Replies
Dear gurus,
Is it possible to create a revolved or a removed section view in inventor IDW. That is whatever being cut in the section plane is to be visible, and not the parts in the background.
Some idea similar to front and back clipping planes.
thanks in advance, email me at mahadevan@vinzagroup.com
5 REPLIES 5
Might try a Breakout view.
Make the view active(red broken outline)
Type: s (for sketch) you will then have a sketch on that view.
Sketch a rectangle/whatever encapsulating the geometry (use project geometry
tool to nail it down same as a regular sketch).
Exit sketch.
RMB on view
Pick Create View then pick Breakout.
The dialog will let you select the depth of cut.
~Larry
"mahadevan" wrote in message
news:f19b28a.-1@WebX.maYIadrTaRb...
> Dear gurus,
what a shame ! have been using IV8 for few months and dunno about this
feature 'till today. Thanks, Larry
"Larry Caldwell" wrote in message
news:5774EE567BC177D87D9466CD7775ECA4@in.WebX.maYIadrTaRb...
geometry
> Exit sketch.
> RMB on view
> ~Larry
> > Dear gurus,
inventor
You're not alone, some of us have been using IV for several years and
still run across features we've never used.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
Thank you Guru, thank you very much
I have problem when I try to do breakout view in Isometric view. I have no idea about the depth. Most of the case I use through part.
