If you open the copied IDW in Design Assistant, you should be able to
use DA to create copies of the parts you want different. After doing
this, open the IDW and validate that it is connected to the copied part
/ assembly files then it should be safe to edit the parts to the new sizes.
James Gralinski wrote:
>Thanks for the responses.
>I understand about taking an assy file (.iam) and doing a file saveas to a
>new one, calling the new one up on the screen, opening the part to be
>revised, doing a file saveas on that and doing a replace component.
>My problem is in the idw file.
>I have a frame for a large conveyor that will be the same for another
>project except that one structural member (frame leg) will be longer for one
>project vs another.
>I have about (7) drawing sheets in the same (idw) for the conveyor frame.
>Do I have to create a whole new drawing, and add all the same dimensions,
>notes etc to get documentation for the different frame?
>thanks
>Jim
>"Wolfe" wrote in message
>news:973314DE27CCCFBB8E937A0936B6038D@in.WebX.maYIadrTaRb...
>>Do save as (with new name) of IPT and IAM files.
>>Open new IAM file, in the browser click on the old IPT file,
>> RMB and select replace Components, replace with new IPT file,
>> perform your revision to the new IPT file.
>>That is my thought.
>>Wolfe
>>"James Gralinski" wrote in message
>>news:82E54B2C83F9721E00302034E11F19D5@in.WebX.maYIadrTaRb...
>>>Hi all,
>>>I need help on revised drawings.
>>>The company I am working for wants to save part files and assembly files
>>>that get revised with a new name.
>>>For example:
>>>SCRT01.iam and SCRT01.idw become SCRT01-A.iam and SCRT01-A.idw for
>>Revision
>>>A
>>>Does this mean that I have to recreate the SCRT01-A.idw from scratch?
>>>Thanks,
>>>Jim Gralinski
