Is there any way you can use the "Application option" "user name" in a revion table column?
The "APP'D" by "Author" is not very helpful considering most changes are done by various people.
If this is not an option could it possibly be added?
Hi Robert,
thanks for your contribution, I looks like it has to be changed manualy now. I'll forward this to product designer to review it.
Jan
It's aberrant that there is no way of getting the name of the person who does the revision!
I can't see any issue provided in Inventor 2013. When will it be corrected???
Robert,
Another way you can have your voice heard is to post this in the Inventor IdeaStation
This way if you explain it thoroughly and concise. It will get heard and the more support it gets from other users the better chance it has to get implemented.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
No problem.
If you do post an idea, please post a link here so we can review it and vote for it.
Hi robert,
Would you be open to the idea of an iLogic workaround? If so you can write the User Name to the Approved By property using this line:
iProperties.Value("Status", "Eng. Approved By" ) = ThisApplication.GeneralOptions.UserName
I would set this up as an external rule, and probably set it to run when the file is saved, using and event trigger. Here are a couple of links that might help if you've not used iLogic before:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
http://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
Of course this is just a workaround, I'd still take Cadmanto's advice and submit the request to the IdeaStation.
I hope this helps.
Curtis
