I just created my first template, and everything works fine until i created a new revision table.
I went to styles editor and made my own and saved it and replaced the default revision table.
And then i saved my template again, but when i open a new drawing the default revision table still shows.
Anyone know how to fix this problem ?
Kind regards
Johan
Welcome Johan.
When you say you replaced the default, do you mean that you set your new table in Object Defaults, inside the Styles Editor?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Johan,
Welcome to the forum.
Are you using vault by any chance?
I ask because the revision table can be driven by vault.
When you say you saved the revision table to the styles, are you an administrator to your system within the Inventor session?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hey
Yeah i am an administrator for my system, and ive made all my settings so far by checking the forums.
But i solved the problem by changing my layer to my saved revision and saved my template.
Dont got vault yet, used it at another company and i really liked it.
Kind regards
Johan Larsson
