I am using IV2013. I am attempting to insert a revision table in some drawings created around 2005 or before. I find that the Description column in the revisiion table is centered justified both in the Heading and in the Comments. I want the comments to be left justified. So I go to Edit Revision Table Style and right click on the Description column and set the Value to right justified. Save. The value is still center justified. I used to be able to do this in prior releases. What is wrong?
In Inventor 2013, you can edit the Revision Table, select the column heading "Description" to highlight the column and right-click to Format Column. You can control the justification for the heading and value separately.
