Inventor General Discussion
0 Kudos
Post 1 of 11
Revision table description justification
328 Views, 10 Replies
07-13-2009 05:19 AM
is there a way to set the justification to left in the revision table justification? I've tried playing with the formats and I can't get it to do anything but be centred.
*Dennis Jeffrey
Post 2 of 11
Re: Revision table description justification
07-13-2009 06:04 AM in reply to: johnny01
You need to edit the annotation style BEFORE you use it - 2010.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
0 Kudos
Post 3 of 11
07-13-2009 07:16 AM in reply to: johnny01
I tried that and still didn't work. Could it be a problem in my template file since I have already created a revision table? Do I need to start a new template file with no revision table?
*Dennis Jeffrey
Post 4 of 11
07-13-2009 07:30 AM in reply to: johnny01
Yes. What version of IV?
0 Kudos
Post 5 of 11
07-13-2009 07:39 AM in reply to: johnny01
2009
64 Kudos
Post 6 of 11
07-13-2009 08:33 AM in reply to: johnny01
If you select the table, can't you just select the style in the pulldown? Try switch to a different style then back if just clicking the current style doesn't update it. (I don't have any drawings yet in my current project so I'm not checking if this works.)
0 Kudos
Post 7 of 11
07-13-2009 08:36 AM in reply to: johnny01
I tried that and it didn't update.
64 Kudos
Post 8 of 11
07-13-2009 08:52 AM in reply to: johnny01
Place a new one with the new style then copy and paste the entries. That's all you can do. Everything else works that way but not the rev table, I remember now.
Distinguished Contributor
5 Kudos
Post 9 of 11
07-13-2009 12:30 PM in reply to: johnny01
When opening the format how are you doing it? To make achange you need to go to the format dir and open from there. That could be part of your problem. Rather than the open format pulldown.
msk
1 Kudo
Post 10 of 11
12-04-2012 09:58 PM in reply to: johnny01
I am using IV2013.  I am attempting to insert a revision table in some drawings created around 2005 or before.  I find that the Description column in the revisiion table is centered justified both in the Heading and in the Comments.  I want the comments to be left justified.  So I go to Edit Revision Table Style and right click on the Description column and set the Value to right justified.  Save.  The value is still center justified.  I used to be able to do this in prior releases.  What is wrong?
