Hi - I have created an assembly by constrain number of part files and generated a drawing file as rev A. Now i have to create a new revsion for the same drawing but some of the assembly components has to be updated. The problem is if i update the ipt file which i used for the assembly it will update Rev A idw file also. i dont want that to happen.
i tried one option, copied the assembly file and renamed to rev B. but again the assembly component part files will remain same. In this case the only option available is copy individual components and replace with the existing components or any other simple options are available ? any option available to break the link ?
My main assembly file contains some sub assemblies also.Those are generated by using frame generator option.
Please help... its very urgent...
Solved by fakeru. Go to Solution.
Without vault... You would have to copy a new model structure for each revision based on your description of your workflow...
However I have a question... Is there a reason why revision B of the drawing/model can not reside on the same drawing as revision "A"?
No am not using vault.. copy model structure means ?
No... Rev A is already submitted.. So If i again re submit with same rev it may be confused.. i mean the drawing will not match (future ref.)
I would make a copy of .idw rev. A and name it rev.B. Before making changes to parts, open .idw rev.A and enable defer update from Document Settings. Then make your changes, rev.B will update, rev.A not.
This is what i need... Thanks.
When i enable defer updates i can see a variation in resolution of the shaded view. any solution avilable ?
Can you post a screenshot?
Please see the attached screenshots. I have named the files as "Befoe & After_Defer updates"
Check the Bitmap Resolution in the Document Settings, under Drawing tab. Choose the biggest value.
Update: Checked myself with a defer update drawing and unfortunately the option is greyed out and you can not change it. Before making the drawing defer update you have to choose the best resolution and then make it defer update. Now if you disable defer update, your drawing will update to rev.B and that's not good. If you have a backup of your assembly and part files together with idw file then you are ok.
@fakeru wrote:Check the Bitmap Resolution in the Document Settings, under Drawing tab. Choose the biggest value.
Thanks for your reply.....
I have given the max resolution 300 DPI. But still the result is same...see the attachment
That's strange... Make it 50dpi and see if it will change, then make it 300dpi again.. That's the only suggestion I give.
Or may be you can attach the idw together with the iam and ipt files and I will try it.
@fakeru wrote:That's strange... Make it 50dpi and see if it will change, then make it 300dpi again.. That's the only suggestion I give.
yes... I tried both 50 dpi and 300dpi but remains same..
Actually its a big assembly file having lot of part files . So if send the idw i should attach all, then the file size will be bit big..
I willl try some R&D..... and let u know if i get a +ve result .
Thanks for your support... it was so helpful ..
