Is it possible to specify a different Revision History Revision Number in Inventor 2010. When I right click on my Revision History Block and select Add Revision Row it automaticly puts a number in the Revision Number section. I would like this to be a letter instead of number. Is this possible without selecting in the Revision Number section and typing in the letter.
Robert
That is determined when placing the Revision Table.
I don't see a way to change that without deleting the table and re-placing it.
Mike
Thanks Mike, That is exactly what I was looking for.
Robert
May be I still don't understand the question??
You are correct that within the IProperties you can manually change the revision number or letter and it will update your revision table and border. What I wanted my revision table to do is whenever I right click on the revision table and select Add Revision Row it would automatically add the next letter to the table and border without having to manually edit table by either double clicking or by going into the IProperties. This makes the revision table more consist and also makes for less error.
