is it possible to do an individual revision table for multiple sheet drawings. if you typed in description 'sheet 3 nut changed from m3 to m5......etc' then all the bunf would carry over to every sheet
Solved by barry.ashcroft. Go to Solution.
sussed it
as you enter the rev table on new sheet it offers you the option of whole dwg or active sheet only.
once this is decided you have to delete and rplace to change it as an after thought.
beware you need to manually update that sheet thereafter though.
happy days
