Inventor General Discussion
Distinguished Contributor
4 Kudos
Post 1 of 3
Reusing Inventor 2014 DWG titleblock info/sketch with Inventor 2014 IDW, how?
1131 Views, 2 Replies
09-26-2013 08:41 AM
I currently have possession of a 2014 Inventor DWG that shows the current titleblock information.  I wish to reuse this particular titleblock in a 2014 Inventor IDW file.
How do I go about copying the titleblock from the DWG to the IDW?
Any tips, suggestions or errata would be appreciated!
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013, 2014 & 2015
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
Hi
I hope that I understand your question correctly, as the solution apears to be too simple. (You do state that it is an Inventor DWG)
Option 1
Open the DWG, then "File, Save as" OR "File,Save copy copy as Template" Change the file type from "Inventor Drawing files (*.dwg) TO Inventor Drawing Files (*.idw)
Option 2:
Open the DWG file
Copy the Title block from from "Drawing Resources, TitleBlocks." (RMB, Copy)
Start a new Drawing.
Delete the Current title block, Listed Under Sheet.
RMB on the Drawing Resources, select paste.
It wil either prompt you to overwrite the current title block, or it will paste a new title block if it was named differently.
Insert the new title block as per normal.
Save the file as a template, or drawing file. (IDW)
Valued Mentor
62 Kudos
Post 2 of 3
Re: Reusing Inventor 2014 DWG titleblock info/sketch with Inventor 2014 IDW, how
09-26-2013 04:21 PM in reply to: JimStrenk
Hi
Option 1
Option 2:
Open the DWG file
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
4 Kudos
Post 3 of 3
09-27-2013 07:00 AM in reply to: rhasell
Thank you rhasell for the quick reply.  Your assistance is appreciated!
I used your Option 1 suggestion and got the results I was looking for.  I got lost by thinking too much on this subject.  :smileyhappy:
Jim Strenk
