Hello Guys,
Can anyone please tell me how to retrive circular pattern holes dimesnions from the model. i can get other dimensions but struggling with holes. i have attached the image.
What version are you running? I am running 2012 and if I create a pattern I can import the hole dimensions using this command.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
