Inventor Forum
Retrieved Dimensions and Hole Notes
0 REPLIES 0
Message 1 of 1
83 Views, 0 Replies
I just started to take another look at Retrieved Dimensions since
ideally all relevant information regarding a part should be stored in
its model.
I noticed that for holes IV does not create a Hole Note. Instead it
creates a simple diameter dimension. For a C'Bore IV is only putting
a diameter dimension on the large diameter. This is certainly not
what most people want.
This is not a huge problem since Hole Notes can use part tolerances.
It is just an inconvenience.
Now I have a 4 digit tolerance on some holes of my part. All digits
are displayed by Show Dimensions in the part file. In the drawing the
hole note shows only 3 digits even though it is set to use part
tolerances and its dimension style is set to show 4 digits for
tolerances.
Is there any way to make the hole note show 4 digits without overriding
the tolerance in the hole note (uncheck Use Part Tolerance)?
Matthias
0 REPLIES 0
