I was wondering if a rectangular pattern can be adaptive?
I have two parts in an assembly which are fastened together with a bolt pattern. The main hole feature geometry of part 2 was projected onto part 1, therefore rendering it adaptive. Hole location and size of the two parts change in unison, but the hole pattern does not change automatically. I have to edit the hole pattern in part 2 and then make part 1 current and edit its hole pattern. Is there a fix for this? Thank you in advance.
