Inventor General Discussion
New Member
sgt.borup
Message 1 of 5 (560 Views)
Restriction of a constraint.
560 Views, 4 Replies
02-15-2011 12:13 AM
Hello Inventor users ! I see myself as a quite experienced user in autodesk inventor, and i have used it regularly the last couple of years, but one thing that has been buggering me the last couple of weeks, is regarding constraints.
is it possible to restrict a constrains movement along an axis (S) at some sort?, for example a cylindrical object with a metal rod going through it, then limit the cylindrical object to only make it able to move for example 10 centimetres (ΔS) ?
Active Member
dacecrown
Message 2 of 5 (552 Views)
Re: Restriction of a constraint.
02-15-2011 12:43 AM in reply to: sgt.borup
they indroduced this facility into 2011, which version are you using?
New Member
sgt.borup
Message 3 of 5 (543 Views)
02-15-2011 01:30 AM in reply to: sgt.borup
Im using Inventor 2008, could you supply possibly supply me with screenshots ? since my school have 2011 :-)
Active Member
dacecrown
Message 4 of 5 (534 Views)
02-15-2011 02:01 AM in reply to: sgt.borup
as you can see, there is a new button >> which extends the contraint box
you now have the limits tab where you can select your maximum and minimum values, the 'use offset as restin position' is a kind of snap button.
so align along your centre axis as normal, then add a face constraint using the 2 additional max and min values to limit your movement.
*Pro
Dennis_Jeffrey
Message 5 of 5 (508 Views)
02-15-2011 03:27 AM in reply to: sgt.borup
For Inventor 2008, you will want to use this:
http://teknigroup.com/tutorials/Inventor/restrictiveTransConstraint.html
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
