Hey all,
I did something following which the view of the inventor has been changed and now I am unable to find get the default outlook/view back.
Below is the user interface I would like to change to default.
Please help me change it as it is quite difficult to cope with.
Solved by CCarreiras. Go to Solution.
Hi! Do you see the upward arrow button on the menu in far right? Click it a few times to cycle through the layout. Or, you can simply right-clcik on the Ribbon bar -> Ribbon Appearance -> Reset Ribbon.
Thanks!
does not work for me I would like the default one he is showing as well.
thanks!!!
Hi Robert,
Do you mind showing a screenshot of Inventor window? I would like to see what state the ribbon panel is at on your machine.
Many thanks!
Double post.
I started having the same problem this morning. I right clicked in the ribbon and tried to change the appearance but it will not change back to normal. I also tried the drop down arrow next to the A360, and it won't change.
I have rebooted my machine and it didn't help. Any other suggestions?
***UPDATE, I got it fixed, thanks.
We had a similar issue where the Inventor Ribbon was unresponsive to changes from Small, Large, Compact, etc - We had to restart the computer for the Inventor Ribbon to accept changes.
You might want to give more details about what you're seeing with the Ribbon interface
But I would start here by clicking on that button a few times to toggle through the ribbon interface design..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Pretty sure that's the fix. That button is small and easy to hit by accident and not know. But that was the answer I needed back when I posted this question.
Thanks Mark!
Well that was easy, just to clarify, there are four options. Repeat clicking until desired view.
Thank you so much!
I was expending a lot of time to restore without success!
Regards....
