Start a new sheet, place view at 1:1, select the crop view to isolate the
section you want
IV2010-Pro-sp1
Vista Business 64bit Sp2
Core i7 950 @ 3.07Ghz
12Gb DDR3-1600, 4 x 60 Gb SSD - RAID0
Quadro FX3800 - 191.00
SpacePilot 3.8.1 / 6.8.1
AVG8.5
"gordow" wrote in message news:6298715@discussion.autodesk.com...
OK, I can't figure this out. I have an assembly that is too large to fit on
a C-size drawing in 1:1 scale, but I need to print out a portion of the
assembly 1:1 so a test fit could be done. I inserted a base view (top
orientation) into a C-size sheet at 1:1 scale to do so. The view overlapped
the edges of the drawing, but I got what I needed when I printed it out.
I later found that I needed a bit more of the assembly in the view (still at
1:1), so I changed the sheet size to D-size. I found that only the portion
of the view that was in the original C-size drawing view window was in the
view as I expected it would be. So I figured I could just insert another
base view to get the entire assembly again, but I just get the portion of
the assembly that was on the sheet of my original C-size drawing. As the
view was placed, the entire assembly was shown, but after placing the view
only the portion of the assembly in the original C-size drawing that was on
the sheet was in the view. Next I tried a NEW drawing and inserting a base
view, but I still only get the portion from the original C-size drawing.
(This hints that there is something in the assembly that is controlling
this.) I then just tried inserting a 1:4 scale view to get the entire
assembly on the sheet but still only get the portion of the assembly in the
original C-size drawing. I have also tried inserting a custom view and a
projection from a view and still get the original drawing view window in the
C-size drawing.
How can I get the full top orientation back in the view window? Can the
view window be resized?
Thanks for any help or suggetions.
gordow
Inventor Pro 2010
