Inventor Forum
Reregistration of Inventor.EXE?
8 REPLIES 8
Message 1 of 9
TimShaul
1477 Views, 8 Replies
I get this Error when opening Inventor, sometimes not every time.
Inventor.EXE needs to reregister with the operating system and the following progrmes (Explorer)are running and may prevent reregistion from successfully completing. Autodesk recommends terminating the offending processes to ensure proper reregistion. Terminate these processes before continuing with the reregistion?
Do you know what is wrong? Explorer is not allways open when I start Inventor.
8 REPLIES 8
Message 2 of 9
in reply to: TimShaul
You'll see this if you use Inventor 5.3 then use
Inventor 6.  If you answer "no" to the question to terminate the process,
Inventor 6 will run fine.
That message doesn't mean Windows Explorer or
Internet Explorer.  It means Explorer.exe - the heart of the Windows
operating system.  It's always running.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Inventor.
Message 3 of 9
Explorer is always running - it is the Windows Interface, you do not necessarily have to fire up
Windows Explorer.
John Bilton
Message 4 of 9
I get this every time I launch R6 after having run R5.3. Don't know the
cause but it doesn't result in any problems.
There was a thread about this a while ago.
Richard
> Inventor.
Message 5 of 9
TimShaul
ok, thanx
Message 6 of 9
Inventor installs some "extensions" to Windows Explorer (Pack n Go, Design Assistant etc.) which are
different between 5.3 and 6. Restarting the shell is usually all that's required, although for
safety I would recommend a reboot.
John Bilton
Message 7 of 9
When I had both versions on my machine, I logged
off then logged back on every time before changing to the other
version.
~Larry
I
Inventor.
Message 8 of 9
kkelly2
Shell????....I have the same problem and it will not allow me to run Inventor at all.
I think is a Inventor---XP problem
Message 9 of 9
Been there done that worn the funny hat got a
plastic mack and holes in my wellies, solution :-    Uninstall
6.0- now 5.3 starts for a blink of an eye- uninstall 5.3- now clean out every
thing called Autodesk and start again. Good luck.
Laurence,
Power is nothing without
Control
Shell????....I
