Solved by JDMather. Go to Solution.
i assume you mean Product Design Suite and not Autocad Design suite 2 completely different suites
since your posting in the Inventor Forum the Autocad Design Suite doesn't come with Inventor
OS requirements for Product Design Suite 2015
32-Bit OS: Microsoft® Windows® 7 (SP1) Home Premium, Professional, Ultimate, Enterprise¹ 64-bit OS: Microsoft® Windows® 7 (SP1) Home Premium, Professional, Ultimate, Enterprise Microsoft® Windows® 8.1 Pro, Enterprise ¹ Exceptions: Autodesk® 3ds Max® Design, Autodesk® Navisworks® Manage, Autodesk Navisworks® Simulate, and Autodesk® ReCap™ are not supported on a 32-bit operating system. |
DarrenP
@ttoedtman wrote:
... But it has Win7 Home Premium OS
I am running fine on Win7 Home Premium OS.
It seems you are confusing AutoCAD and Inventor in this thread? These are two different Autodesk products.
Is this a student license?
The student license in fully functional Inventor Professional - only the terms of use are different.
@ttoedtman wrote:
I believe its called Inventor LT
Ah, Inventor LT is limited as follows
No assemblies (but can do multi-body which is sort of like assemblies, without motion).
No sheet metal.
and maybe a couple of other things.
