Crash confirmed. It also behaves the same way on the top plate.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5983972@discussion.autodesk.com...
Open up the assembly 208529-29sks.iam. Activate the 12637-10sks.iam from
within the assembly and edit the rectangular pattern. Go ahead and
re-select the directions that are already used, then click ok and say
goodbye. If you open the file and make the same edit, it doesn't crash, but
if it is activated it does.
