Inventor Forum
Reproducible Crash in IV2009
2 REPLIES 2
shastu
126 Views, 2 Replies
Open up the assembly 208529-29sks.iam. Activate the 12637-10sks.iam from within the assembly and edit the rectangular pattern. Go ahead and re-select the directions that are already used, then click ok and say goodbye. If you open the file and make the same edit, it doesn't crash, but if it is activated it does.
2 REPLIES 2
in reply to: shastu
Crash confirmed. It also behaves the same way on the top plate.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5983972@discussion.autodesk.com...
johnsonshiue
in reply to: shastu
Thanks! I am able to reproduce the problem also. I am forwarding it to development.
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
