I'm using INV 2013 pro. I have an assy with severals views in representation. the problem is that I can't see any component when I activate one of them.
The IDW using this iam and those views, presents no error though.
how can I see those components in the iam back?
PS the only solution I found is to re-make the same view (same name) each time I open the iam.
Is this only happening with this file or can you repeat this behavior in other files.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
