I've created a set of "generic" equipment drawings for a client. Whenever the client has a new piece of equipment fabricated from the drawings they assign it an equipment number (for sake of argument let's say the number is "426"). The generic drawings don't have a number, instead they have a "XXX" wherever the number should be. Every time they fabricate off of the drawings they revise 100+ drawings to show the equipment number where the X's are. I am looking for a piece of iLogic code or something that will help me replace the "XXX" with the equipment number so that I don't have to do it manually.
Now before anyone says it, I will: this is a dumb system. I've tried to convince the client that since the "generic" set of drawings never changes then they should also have a number that never changes. For some reason the client is not willing to try it this way, they want to continue duplicating and renumbering the drawings for every new piece of equipment.
Any help or ideas would be greatly appreciated.
Solved by Curtis_Waguespack. Go to Solution.
I'm no expert but I'll take a stab at this. If you could have this model driven than it is doable. I'll assume for this it is one big assembly. You could open the top level assembly and go manage > bill of materials. In here you could create a custom iproperty, say called job number. This column will be inserted and here is your custom iproperty. You can thus highlight all rows and expand all. With this you could enter a job number and then paste it to every single item in the assembly. This would then have every assembly and part with a custom iproperty job number with whatever your current job number is. You could then have this custom iproperty on all the drawings to be pulled from the part that's inserted. Might take some setting up but you could in the future open the main assembly bom, highlight every "job number" custom iproperty and change them all simultaneously. Then simply run task manager to update drawings. This would accomplish the task you are asking for. Not sure if this is the best way for your scenario but I have used it in the past. Let me know if this helps you
Also you could put the custom iproperty into one drawing and have that setup. You could then use the Drawing Resource Transfer Wizard to apply the new drawing template to all other drawings in one shot versus opening and changing them one by one.
Is it just the drawing number that needs to be updated each time or do you also have numbers within the drawing field as well (as your title alludes to)?
There might be a few ways to do this based on your answers.
iLogic could be one of tham along with Task Manager and maybe even Copy Design in Vault if you have Vault installed.
Jim O'Flaherty
Come to think of it you could make a custom border that includes the new job number as part of it. Using the tool Drawing Resource Transfer Wizard you could then transfer the border to every drawing. This is a bit of a hack way to do it but the change would stay permanent with the drawing and accomplish your goal.
It is not just the drawing number, it is also leader text and other text/labels.
While some of the suggestions on here are good I am trying to avoid redoing 200+ drawings (each new pieve of equipment may only have 100 or so drawings but there are over 200 in the "generic" set). I realise that there are/were better ways of creating these drawings but unfortunatley the client was directly involved and is used to using AutoCAD (which has find & replace). He was also pretty unwilling to bend his thinking. Made it very difficult to make these drawings "intelligent". At this point I am just trying to make the best of what we have.
Hi dschleede,
Here is an iLogic rule that looks at General Notes, Leader Notes, Title Block Field Text, and Sketched Symbols Text and will replace their values when they match the user input search string.
Post back if there are other text items that you need the iLogic rule to search through.
I hope this helps.
Curtis
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oGeneralNotes As GeneralNotes
Dim oGeneralNote As GeneralNote
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
Dim oTitleBlock As TitleBlock
Dim oTestBox as TextBox
Dim TXT2Find As String
Dim NewTXT As String
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
End If
NewTXT = InputBox("Enter Text To Replace '"& TXT2Find _
& "' with.", "iLogic", "****")
oSheets = oDoc.Sheets
For Each oSheet In oSheets
Try
oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
'look at gerenal notes
For Each oGeneralNote In oGeneralNotes
If oGeneralNote.FormattedText = TXT2Find Then
oGeneralNote.FormattedText = NewTXT
Else
End if
Next
oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
For Each oLeaderNote In oLeaderNotes
If oLeaderNote.FormattedText = TXT2Find Then
oLeaderNote.FormattedText = NewTXT
Else
End if
Next
oTitleBlock = oSheet.TitleBlock
For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
If oTitleBlock.GetResultText(oTextBox) = TXT2Find Then
oTitleBlock.SetPromptResultText(oTextBox, NewTXT )
Else
End If
Next
oSymbols = oSheet.SketchedSymbols
'look at sketched symbols
For Each oSymbol In oSymbols
For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes
If oSymbol.GetResultText(oTextBox) = TXT2Find Then
oSymbol.SetPromptResultText (oTextBox, NewTXT)
Else
End if
Next
Next
Catch
'do nothing here,
'this simply catches errors, for
'exampl: when a sheet has no title block
End Try
Next
**** Updated version ****
The Try/Catch I had in the first version didn't work as intended.
This new version should work as expected, just disregard the previous version.
I should point out also that this iLogic does not handle Sketched Symbols where the static text matches the searched text, as it is only looking at the prompted/field text in the symbols.
I hope this helps.
Curtis
oDoc = ThisDoc.Document Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView Dim oGeneralNotes As GeneralNotes Dim oGeneralNote As GeneralNote Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols Dim oTitleBlock As TitleBlock Dim oTestBox as TextBox Dim TXT2Find As String Dim NewTXT As String 'get user input TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX") 'look for blank value If TXT2Find ="" Then Return 'exit rule Else 'Continue rule End If NewTXT = InputBox("Enter Text To Replace '"& TXT2Find _ & "' with.", "iLogic", "****") 'look for blank value If NewTXT ="" Then Return 'exit rule Else 'Continue rule End If oSheets = oDoc.Sheets For Each oSheet In oSheets 'handle errors On Error Resume Next 'look at gerenal notes oGeneralNotes = oSheet.DrawingNotes.GeneralNotes For Each oGeneralNote In oGeneralNotes If oGeneralNote.FormattedText = TXT2Find Then oGeneralNote.FormattedText = NewTXT Else End if Next 'look at leader notes oLeaderNotes = oSheet.DrawingNotes.LeaderNotes For Each oLeaderNote In oLeaderNotes If oLeaderNote.FormattedText = TXT2Find Then oLeaderNote.FormattedText = NewTXT Else End if Next 'look at title blocks oTitleBlock = oSheet.TitleBlock For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes If oTitleBlock.GetResultText(oTextBox) = TXT2Find Then oTitleBlock.SetPromptResultText(oTextBox, NewTXT ) Else End If Next 'look at sketched symbols oSymbols = oSheet.SketchedSymbols For Each oSymbol In oSymbols For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes If oSymbol.GetResultText(oTextBox) = TXT2Find Then oSymbol.SetPromptResultText (oTextBox, NewTXT) Else End if Next Next Next
I tried your code but it doesn't seem to work. It didn't replace any of the "XXX"'s with the other number. Perhaps I am doing something wrong.
Hi dschleede,
It's possible that you have something in your drawings that are a departure from what I tested. Attached is a sample file that you can look at to see how this is working, and hopefully determine what is different than your file(s). If so you might provide some screen shots of your files to help others better understand what you're working with. But I suspect my example is too simple compared to your real world files.
I hope this helps.
Curtis
It works in your example until you change all of the text so that the XXX's are contained inside other text.
ie: 55XXX-A01
Then it fails.
Maybe this can't be handled with iLogic? I though maybe it'd be possible to throw a wildcard in there somewhere but I've read that ilogic doesn't support wildcards.
If you are still at a loss with this, I have something similar that I use with my Certification drawings. Typically a client assigns a Tool number and I have lots of text in my drawings that reference this number (general notes, drawing number, titleblock, etc..) I use the iLogic Form function along with custom iProperties to populate all my text. So for instance, I open the form, enter the tool number and after applying, the text is filled in with the number at the locations I specified. It does take a bit to setup (you will have to go through all your text and title block and add in the custom iproperty). But once finished, it is very simple and effective. See some screen caps below...
Update to this to find string that contain the search string as requested in the past:
Sub main oDoc = ThisDoc.Document Dim oSheets As Sheets Dim oSheet As Sheet Dim oGeneralNotes As GeneralNotes Dim oGeneralNote As GeneralNote Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols Dim oTitleBlock As TitleBlock Dim oTextBox as TextBox Dim ooTXT2Find As String Dim oNewTXT As String 'get user input oTXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX") 'look for blank value If oTXT2Find = "" Then Return 'exit rule End If oNewTXT = InputBox("Enter Text To Replace '" & oTXT2Find _ & "' with.", "iLogic", "ZZZ") 'look for blank value If oNewTXT = "" Then Return 'exit rule End If oSheets = oDoc.Sheets For Each oSheet In oSheets 'handle errors On Error Resume Next 'look at General Notes oGeneralNotes = oSheet.DrawingNotes.GeneralNotes For Each oGeneralNote In oGeneralNotes oText = oGeneralNote.FormattedText oText = ReplaceText(oText, oTXT2Find, oNewTXT) oGeneralNote.FormattedText = oText Next 'look at leader notes oLeaderNotes = oSheet.DrawingNotes.LeaderNotes For Each oLeaderNote In oLeaderNotes oText = oLeaderNote.FormattedText oText = ReplaceText(oText, oTXT2Find, oNewTXT) oLeaderNote.FormattedText = oText Next 'look at title blocks oTitleBlock = oSheet.TitleBlock For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes oText = oTitleBlock.GetResultText(oTextBox) oText = ReplaceText(oText, oTXT2Find, oNewTXT) oTitleBlock.SetPromptResultText(oTextBox, oText) Next 'look at sketched symbols oSymbols = oSheet.SketchedSymbols For Each oSymbol In oSymbols For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes oText = oSymbol.GetResultText(oTextBox) oText = ReplaceText(oText, oTXT2Find, oNewTXT) oSymbol.SetPromptResultText(oTextBox, oText) Next Next Next End Sub Function ReplaceText(oText As String, oTXT2Find As String, oNewTXT As String) If oText = oTXT2Find Or oText.Contains(oTXT2Find) Then oText = Replace(oText, oTXT2Find, oNewTXT) End If Return oText End Function
