style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"jclark" <I
href="mailto:lostbears@worldnet.att.net">lostbears@worldnet.att.net>
wrote in message
href="news:f12530c.1@WebX.maYIadrTaRb">news:f12530c.1@WebX.maYIadrTaRb...
wouldopen the part and jerk it around a little to make sure aht it is a good
part. I have had some strange things happen once in a while. Waht I do is save
the assembly and shut down completly. Restart and open the assembly and try
again. thy bringing some other part in and se if taht will also cause a crash.
Every once in a while I wil try to move or rotate by constraints some thing
that is aready set, instead of the red cross I get a instant close of inventor
and I am looking at my desktop. Just try to work around
it.
"Keith Bender" <
href="mailto:thebend@earthlink.net">thebend@earthlink.net> wrote in
message
href="news:7E45131E69468ABE2373DF42CC424122@in.WebX.maYIadrTaRb">news:7E45131E69468ABE2373DF42CC4......
Yes, I've discovered that it is just this one
.IPT that seems to be creating the problem (it was created fresh in
IV6SP1). I'll be doing some more experimenting with it to see just what
feature (or whatever) is causing the problem. I tried a total rebuild of
the part, and received access violation error, power exits, etc... If I
get time, I might upload to CF tomorrow and see what others find. So
far, I've seen troubles rotating the part within an assembly, moving within an
assembly, constraining within an assembly, rebuilding the .ipt, saving the
.ipt, opening the .ipt, etc... I'll probably start deleting features to see
what is offending (I'm suspecting emboss of a custom truetype
font).
"jclark" <I
wrote in message
save the assembly and shut down completly. Restart and open the assembly and
try again. thy bringing some other part in and se if taht will also cause a
crash. Every once in a while I wil try to move or rotate by constraints some
thing that is aready set, instead of the red cross I get a instant close of
inventor and I am looking at my desktop. Just try to work around
it.
"KJohnson" <kj@sensoft> wrote in
message
href="news:9DBD863E0051D7A88C6DE8AAAFC00500@in.WebX.maYIadrTaRb">news:9DBD863E0051D7A88C6DE8AAAFC......
Try this roll up the end of part to the first
feature and do a rebuild. Move down a feature, rebuild until you find the
culprit.
Kathy Johnson
"Keith Bender" <
message
href="news:7E45131E69468ABE2373DF42CC424122@in.WebX.maYIadrTaRb">news:7E45131E69468ABE2373DF42C......
what feature (or whatever) is causing the problem. I tried a total
rebuild of the part, and received access violation error, power exits,
etc... If I get time, I might upload to CF tomorrow and see what
others find. So far, I've seen troubles rotating the part within an
assembly, moving within an assembly, constraining within an assembly,
rebuilding the .ipt, saving the .ipt, opening the .ipt, etc... I'll probably
start deleting features to see what is offending (I'm suspecting emboss of a
custom truetype font).
"jclark" <I
wrote in message
good part. I have had some strange things happen once in a while. Waht I
do is save the assembly and shut down completly. Restart and open the
assembly and try again. thy bringing some other part in and se if taht
will also cause a crash. Every once in a while I wil try to move or rotate
by constraints some thing that is aready set, instead of the red cross I
get a instant close of inventor and I am looking at my desktop. Just try
to work around it.
"Keith Bender" <
href="mailto:keithb@aptix.com">keithb@aptix.com> wrote in message
href="news:83B83A18225DF71F219A3BC6FD5F9A83@in.WebX.maYIadrTaRb">news:83B83A18225DF71F219A3BC6FD5......
Thanks Kathy,
I'll try that later and let you know if it
helps.
Keith
message
href="news:9DBD863E0051D7A88C6DE8AAAFC00500@in.WebX.maYIadrTaRb">news:9DBD863E0051D7A88C6DE8AAA......
the culprit.
Kathy Johnson
"Keith Bender" <
message
href="news:7E45131E69468ABE2373DF42CC424122@in.WebX.maYIadrTaRb">news:7E45131E69468ABE2373DF4......
probably start deleting features to see what is offending (I'm suspecting
emboss of a custom truetype font).
"jclark" <I
wrote in message
rotate by constraints some thing that is aready set, instead of the red
cross I get a instant close of inventor and I am looking at my desktop.
it.
"Keith Bender" <
href="news:796969727E24A0095CAA65DFECF5DEC0@in.WebX.maYIadrTaRb">news:796969727E24A0095CAA65DFECF......
I'm still having trouble with this part - quite
often I'll get this message just before crash..."Error loading segment
PmBRepSegment in database\\PATH\FILENAME.IPT.
I tried the rebuild, rolling down one feature at
a time, and seems to sometimes make it through, and other times fails on the
first feature. Seems intermittent. I'll post to CF. Please
if anybody has time, see if you repeat the problem, and have any more
suggestions for fixing.
Thanks, Keith
"Keith Bender" <
href="news:83B83A18225DF71F219A3BC6FD5F9A83@in.WebX.maYIadrTaRb">news:83B83A18225DF71F219A3BC6F......
Thanks Kathy,
helps.
Keith
in message
href="news:9DBD863E0051D7A88C6DE8AAAFC00500@in.WebX.maYIadrTaRb">news:9DBD863E0051D7A88C6DE8A......
the culprit.
Kathy Johnson
"Keith Bender" <
in message
href="news:7E45131E69468ABE2373DF42CC424122@in.WebX.maYIadrTaRb">news:7E45131E69468ABE2373D......
one .IPT that seems to be creating the problem (it was created fresh in
an assembly, moving within an assembly, constraining within an assembly,
suspecting emboss of a custom truetype font).
"jclark" <I
wrote in message
a good part. I have had some strange things happen once in a while.
Waht I do is save the assembly and shut down completly. Restart and
open the assembly and try again. thy bringing some other part in and
se if taht will also cause a crash. Every once in a while I wil try to
move or rotate by constraints some thing that is aready set, instead
of the red cross I get a instant close of inventor and I am looking at
it.
