Inventor General Discussion
*Dotson, Sean
Message 1 of 9 (76 Views)
Repeatable bug...now you try
76 Views, 8 Replies
11-05-2002 03:32 AM
RMB on a dimension in sketch mode in a part. Select Dimension Properties,
go to the Document settings tab and change Show Value to anything else and
hit OK. You should get Serious Error -Access Violation No RTTI data.
BTW the secret top getting out of the dialogue (since the cancel button
doesn't work) is to close the part with the x in the corner...
Hope this one makes it in SP1...(or is it just me?)
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
*Mears, Brian
Message 2 of 9 (76 Views)
Re: Repeatable bug...now you try
11-05-2002 03:38 AM in reply to: *Dotson, Sean
I follow your directions and cannot reproduce the error. Works fine.
"Sean Dotson" wrote in message
news:690898FB90FF5764E2A2D1097BE7263D@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
*Dotson, Sean
Message 3 of 9 (76 Views)
Re:
11-05-2002 03:46 AM in reply to: *Dotson, Sean
hmm.. after a reboot it's working fine now. However I did shut down and
retry it several times... strange...
Sorry for the alarm, nothing to see here, move along...
Sean Dotson, PE
"Brian Mears" wrote in message
news:CF608D4989BF16933479CB6C4A5A82F2@in.WebX.maYIadrTaRb...
Properties,
and
> > Sean Dotson, PE
*Jaquith, Walt
Message 4 of 9 (76 Views)
11-05-2002 03:51 AM in reply to: *Dotson, Sean
Hi Sean,
Working in a simple little part sketch I created for the experiment (one
circle, one dim), I couldn't repeat your glitch. I also tried it on an
existing part and sketch. Nada.
WJ
*Allen, Albert
Message 5 of 9 (76 Views)
Re:
11-05-2002 03:54 AM in reply to: *Dotson, Sean
The force is strong with you Sean, I can sense it.
news:ADE43998A291A42E94744B9BA9D18DCA@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> Properties,
> and
button
> > > Sean Dotson, PE
*Dotson, Sean
Message 6 of 9 (76 Views)
Re:
11-05-2002 03:56 AM in reply to: *Dotson, Sean
the "force" of stupidity?
Sean Dotson, PE
"Albert Allen" wrote in message
news:3D5E3DA025FE7D4382A94AF6D98F575A@in.WebX.maYIadrTaRb...
> > Sean Dotson, PE
> > Properties,
else
> > and
data.
> button
> > > > Sean Dotson, PE
*Keith_Bradford
Message 7 of 9 (76 Views)
Re:
11-05-2002 04:53 AM in reply to: *Dotson, Sean
Yes officer...
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
(Remove All Numbers From E-mail)
> Sean Dotson, PE
> Properties,
> and
button
> > > Sean Dotson, PE
*Autodesk, John Elliott -
Message 8 of 9 (76 Views)
11-05-2002 07:07 AM in reply to: *Dotson, Sean
What OS are you using?
John
> Sean Dotson, PE
*Dotson, Sean
Message 9 of 9 (76 Views)
Re:
11-05-2002 09:50 PM in reply to: *Dotson, Sean
John, it seemed to fix itself after a reboot (see above) but if you are
still curious Win2K sp3
Sean Dotson, PE
"John Elliott - Autodesk" wrote in message
news:4468BBD9DEB523ED650D4D024F3C9CC9@in.WebX.maYIadrTaRb...
> John
Properties,
and
> > Sean Dotson, PE
