I have a part rendered in Inventor Studio- Looks great when I save it as a .bmp and print it. How can I add dimensions and leaders and callout to this rendered imaged?
Solved by DarrenP. Go to Solution.
Solved by blair. Go to Solution.
I would use a desk-top publishing software that will allow you to place the picture in a document and then add tables and text with arrows/leaders. We use Adobe's InDesign software for all our parts catalogues and brochures. I'm sure there is other publishing software out there as well.
if you want to stick with autodesk products
they have something called Inventor Publisher that may do what you want to
DarrenP
