Inventor General Discussion
Member
andrew.cox
Message 1 of 6 (428 Views)
Renaming sheets in a multi-sheet IDW....
428 Views, 5 Replies
10-04-2012 12:04 PM
Is there any easy way to have sheet name automatically pull the "description" iProperty from the part that is on the sheet?  It can be very handy in a multi-sheet drawing for each sheet to have a descripive name in the browser, but the only way to do this (that I know of) is to manually change it.
Andrew
Curtis_Waguespack
Message 2 of 6 (417 Views)
Re: Renaming sheets in a multi-sheet IDW....
10-04-2012 01:21 PM in reply to: andrew.cox
Hi andrew.cox,
Here's an iLogic rule to do this. Note that description might not write to the sheet name correctly if it has characters such as commas in it.
I hope this helps.
Curtis
Dim oSheets As Sheets
oSheets = ThisDoc.Document.sheets
Dim oSheet As Sheet
For Each oSheet In oSheets
	oSheet.activate
	Dim oDrawingView As DrawingView
	oDrawingView = oSheet.DrawingViews(1)
	oModelName = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	oDesc = iProperties.Value(oModelName, "Project", "Description")
	oSheet.Name =  oDesc
Next
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
andrew.cox
Message 3 of 6 (393 Views)
10-05-2012 05:55 AM in reply to: Curtis_Waguespack
Hi Curtis,
Thanks for this info!  However, I have not even used iLogic, so I don't know what to do with this.  Any chance you could point me towards a good tutorial, or provide me instructions yourself?
Cheers,
Andrew
Curtis_Waguespack
Message 4 of 6 (376 Views)
10-05-2012 08:38 AM in reply to: andrew.cox
Hi andrew.cox,
This should cover it:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Member
andrew.cox
Message 5 of 6 (361 Views)
10-05-2012 12:30 PM in reply to: Curtis_Waguespack
Hi Curtis,
I'm having some trouble with the code you supplied.  When I enter in into the "rule", I get this error....
I cut-and-paste the code exactly as you had it in your previous post.  Any thoughts?
Andrew
Curtis_Waguespack
Message 6 of 6 (325 Views)
10-08-2012 07:12 AM in reply to: andrew.cox
Hi andrew.cox,
Most likely there is an issue with a line wrap due to this forums formatting, or something like that. Attached is the rule in a text file, you can copy and paste from it.
If you see the same results post back.
I hope this helps.
Curtis
