Inventor Forum
Removing Secondary Drawing Break Line
3 REPLIES 3
Cadmanto
1502 Views, 3 Replies
As you can see by the attached pic below, I would like to remove the circled break line.  This view I simplified by turning the visibility off of the additional lines to just show the part profile.  Now when adding a break line in the parent view, these break lines in this view are showing up in space.  Any way to turn them off in this case?
Deleting them gets rid of everything.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
3 REPLIES 3
in reply to: Cadmanto
Select view, display options, uncheck "Break" in Cut Inheritance, turn visibility of unwanted lines off.
rdyson
See if this will work for you
Create the projected view
Crop the view to about what you want
Create the break in the base view
Hide any bits of extraneous lines in the projected & cropped view
Or do as dlmsdm1 says
PDSU 2016
Cadmanto
in reply to: rdyson
Thanks guys for the responses.  Editing the view worked just fine and easy.
Sorry, the other method sounds like a lot of work at this point.
Best Regards,
Scott McFadden
