Inventor Forum
Removing compound material from a rolled pipe
6 REPLIES 6
ryanholley2786
338 Views, 6 Replies
Probably something easy I am missing, but I cannot seem to figure this one out. I have 4 plts coming together makiing a large catch pan. tRhe discharge opening is a 14" od rolled pipe (sheetmetal part). I was able to make the cuts in the plates, but how do I get the proper cut in the round pipe?
Ryan Holley
Dell Z400
quad core
12G / 1T disk
64 bit INV2011 SP1
Vault Standard
6 REPLIES 6
JDMather
in reply to: ryanholley2786
Looks like you could Edit the pipe in the context of the assembly and Copy Object as surface bodies the slicing surfaces..  Looks like you might need to do some patching of the surfaces before using to Split or Sculpt.
Attach the assembly here if you can't figure it out.
The CADWhisperer YouTube Channel
ryanholley2786
in reply to: JDMather
Thanks JD! Used sculpt to remove the extra material. Even unfolded after the sculpt!
Ryan
Pics
JDMather
I suspect it is going to take just a bit more work.  Turn that flat pattern over and look at the cut edges from the other side - or change to wireframe view.  You should not see multiple lines at cut edges (cuts perpendicular to flat).
ryanholley2786
Yep, but the alternative was going to be tack the whole thing in there and torch out the unwanted material. Much closer to where I needed to be.
JDMather
I think if you right click on the smaller face side (back side) and export that you will be OK.
