Is there a way to remove the trails from a presentation one they have been added using the tweak components command ? These are shown on the animation but I can't seem to remove them without completely redoing the animation.
I think if you select one and right click you can either remove it or turn it off. Inventor isn't open at the moment, so I can't tell you exactly what the command is.... but I know I've done it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you for your help, I will try that.
Go to Assembly View in the ipn
Select any parts that have a trail (I used Shift select first and last to select all in between) note that the base component was not tweaked.
RMB Hide Trails
I don't have this option. Am I looking in the right place??
There is also an option to not add them when you create the tweak. Then, it seems there is an option to not show them when you place the drawing view.
Thanks for the help. I got stuck then googled it. This thread must pertain to an older Inventor version which only added to my confusion. Thanks!
