Inventor Forum
Remove texture from Project Library
7 REPLIES 7
Message 1 of 8
douthett
1425 Views, 7 Replies
A co-worker decided that he couldn't wait for our Cad Manager to add a texture to the application library so he used it through the project library.
So now I have to figure out how to remove it from the part but I can't figure it out.
Does anyone know how to delete a this texture from the part?
7 REPLIES 7
Message 2 of 8
in reply to: douthett
From where you are - Texture Chooser dialogue box.
You can click the Application Library and select the correct texture from the Application Library.
Or click Cancel and in the Style and Standard Editor click Remove. Then apply the correct texture.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5839219@discussion.autodesk.com...
Message 3 of 8
douthett
That doesn't fix the problem. The texture was used and therefore is still linked to the model.
I need the model so it does not have any 3rd party links and I can't do that until I get rid of the texture
Message 4 of 8
Does the texture appear in Inv's third party folder in the browser - as opposed to the Vault Browser that you are showing me
at the moment?
Duncan
wrote in message news:5839273@discussion.autodesk.com...
Message 5 of 8
douthett
If you mean is it used anyplace like a decal then the answer is no. The image appears to only be used as a texture.
Message 6 of 8
It seems to me that Vault it holding onto that reference and not Inv.
You might be able to hunt it down and delete that link using Vault Explorer.
You might find some more useful advice by posting to
Autodesk Vault
http://www.autodesk.com/discussiongroup-vault
news://discussion.autodesk.com/autodesk.vault
Autodesk Productstream
http://discussion.autodesk.com/forum.jspa?forumID=249
news://discussion.autodesk.com/autodesk.productstream
Duncan
wrote in message news:5839336@discussion.autodesk.com...
Message 7 of 8
From the menu Edit > Links
Message 8 of 8
douthett
That's it!! Thank you!
