Inventor Forum
Remove Text Label From detail Boundary
6 REPLIES 6
shmartin89
1890 Views, 6 Replies
Does anyone know to remove the view label text which is attached to a detail boundary? I know that if you double click ont he etxt you can manually delete it from the format text window but I want edit the default setting so that it doesnt appear on creation.
See attached image.
6 REPLIES 6
Hi shmartin89,
The only way I can see to do this is to go to the Manage tab > Styles Editor button and create a new Text style, called something like Tiny Text, and set the text height to 0.001" or 0.01 mm .
Then edit the View Annotation style and set view type to Detail View, then set the text style to use the Tiny Text style.
I think this will give you the results you're looking for.
I hope this helps.
Curtis
blair
in reply to: Curtis_Waguespack
I'm sure there are a number of standards requiring the detail view reference to which view the detail came from. If you aren't concerned with this reference, then a Crop-View would work as well
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Thanks Curtis_Waguespack.
The is as good as a solution!
Cheers,
shmartin89
in reply to: blair
HI Blair, I will using my own view labels to display the view information.
I have created my own sinnce inventor doesnt allow you to alter the design.
Cheers,
Sandy
t_pcoll
Also, instead of using Tiny Text style it should be allowed to RMB on Detail View fence -> Text... and delete the <VIEW> indentfier.
Ladislav
akap47
in reply to: shmartin89
Well ........ it takes a several steps or tricks with Inventor to perform simple tasks which Mechanical Desktop does in just two clicks.
I can list a dozens if not hundreds most commonly tasks used which Inventor does clumsy job.
