I use one backup and I retrieve it sometimes, not because a file goes
completely bad (I use DataKeeper for that rare event) I use it more to back
out of a mud-hole at the end of a dead-end road. That said, there are other
times when I would like those directories to go visit Jimmy Hoffa.
~Larry
"Sean Dotson" wrote in message
news:793AB3B8C021C9275C3311A69BDC04F1@in.WebX.maYIadrTaRb...
> I have had old version (and versions to keep in preR6) set to 0 for the
> longest time. Since it makes a new version each time you save (and I save
> every 2-5 mins) the "old versions" aren't really that old. In all 7
> releases I have never been successful in retrieving an old file via this
> method. I usually go to the server backup harddrive from the day before.
> Of course I've only had a handful of files go completely bad anyway.
> Personally I find the fact that it create the folder to be quite annoying.
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> www.sdotson.com/faq.html
> "MechMan" wrote in message news:f14c38d.1@WebX.maYIadrTaRb...
> > It can't be turned off. As Larry said though, I don't know why anyone
> would want to work without backups.
> > MechMan
