Inventor General Discussion
Member
Chris86542
Message 1 of 4 (580 Views)
Remove Item from BoM but not Assembly
580 Views, 3 Replies
02-13-2013 12:30 AM
Good Morning All,
First of all I apologise in advance if this question has already been asked. I had a look and couldn't find anything relevant.
I have a drawing in which I need to keep a part in the assembly but I don't want to display it on the BoM. Is there any way I can remove it from the BoM without removing it from the assembly and drawing?
Many thanks.
Chris
cbenner
Message 2 of 4 (567 Views)
Re: Remove Item from BoM but not Assembly
02-13-2013 04:58 AM in reply to: Chris86542
Well, one way I think would be to set the item to "Reference" in your BOM.  Then it will not show in the parts list on your drawing.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Distinguished Contributor
bstewart
Message 3 of 4 (566 Views)
If you're referring to the drawing Parts List, you can double-click the parts list, highlight the row you want to hide, right-click the row and click Visible.
HTH
Bob
____________________________________________________
Product Design Suite Ultimate 2014 | Vault Basic 2014 (SP1)
Dell Precision M6600 | Intel i7-2820QM - 16GB
nVIDIA Quadro 4000M | Windows 7/64 Pro
*Pro
sbixler
Message 4 of 4 (563 Views)
02-13-2013 05:04 AM in reply to: Chris86542
Change it to Reference.  Right click on the component in the assembly (.iam) and select iProperties.  On the Occurrence tab change the BOM Structure from Default (Normal) to Reference.  In your drawing this will also change the linestyle to phantom, but you can edit the drawing view(s) and change the way Reference components are displayed.
You can also make this change in the BOM editor instead of the iProperties box.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
