I've accessed my workstation through our conference room computer with a
remote desktop connection. The screen doesn't update as fast as you would
probably like, but IV is still moving along as fast as usual. I haven't
tried it yet from home, because I'm not sure I want to provide a way in to
the network at this point.
If you do set that up you can log into your workstation (and the vault from
there) or if you use your home computer to run IV, you can log into the
vault and check files out from home. Either way, that would take care of the
file transfer problems.
You also don't have to worry about transferring a license. IV allows two
simultaneous installations for each seat, without transferring anything.
"Bradley Bruns" wrote in message
news:420cb29f$1_1@newsprd01...
> So you're saying that there is a speed decrease? In the example you
> mentioned, do you know if the internet connections were dial up or high
> speed?
> The typical work load for me is creating, assembling, and fully detailng
> an
> inspection fixture, 20-200 machined parts. Bigger than "training" stuff
> but
> not a 5000 part assembly.
> Thanks
> -Brad
> "Sean Dotson" wrote in message
> news:420cac27$1_3@newsprd01...
>> I know at least one person here uses Go2MyPC.com When we were at AU this
>> year he logged into his machine and it was fast enough to view, measure
> and
>> move a few parts. Not sure I'd want to work on a large assembly however.
>> They do have a free trial also.
>> Sean Dotson, PE (AICE)
>> RND Automation & Engineering
>> sdotson.com mcadforums.com
>> news:420caa0f$1_2@newsprd01...
>> > I'm looking into possible solutions for using Inventor from home.
> Working
>> > remotely sounds interesting because it will seemingly eliminate the
>> problems
>> > of needing another expensive workstation, licence transfer, and file
> sync.
>> > What issues are there when using a remote access program, like net
> meeting
>> > or windows remote desktop? How important are the processor, RAM, &
> video
>> > card of the remote computer? How "responsive" will INV be compared to
>> using
>> > the host computer? Both home and work have high speed internet.
>> > Thanks for any advice,
>> > Brad
