Inventor Forum
'Reloading' assembly, how to?
3 REPLIES 3
202 Views, 3 Replies
What is the procedure for reloading an assembly or part within an assembly after it has been modified?
3 REPLIES 3
At the top of the window look for the lightning bolt. That is the update
button. Click this and the modifications will reveal themselves. If you
modified a file then opened the assembly it was in it should update
automatically.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"garyallisonatjoneseng" wrote in message
news:f164791.-1@WebX.maYIadrTaRb...
This does not happen, I am working on an assembly that someone else has loaded into there assembly.
What we want to happen is when I have made some changes we want to reflect these changes in the other persons assembly.
Does this work of the 'update button'?
Yes, if the Muti-User switch is set to "on".
MechMan
