So in order to evaluate the structure would you have to build it and put it through stress analyses? If you could make it clearer because making a complex concrete design would go soother if there were shortcuts that you could tell me about.
@delavavogo wrote:
So in order to evaluate the structure would you have to build it and put it through stress analyses?....
I do not see any information related to analysis in this old thread.
Inventor analysis tools are limited to isotropic materials and relatively non-brittle materials.
Concrete is not isotropic.
Concrete is relatively brittle.
Use caution in interpreting your analysis.
This posting is 11 years old and the individuals that participated in this posting, their accounts are archived an no longer active. Might want create your own posting the next time but it looks like JD has pointed you in the right direction.
Mark Lancaster
& Autodesk Services MarketPlace Provider
So what your saying is that because Inventor bases its analysis on perfect materials it might not accurately predict the point of failure since It cannot calculate the fracture load. Would there be a good rule of thumb I could use to tell when it will likely fail, or is there a better way to evaluate a reinforced structure, perhaps something I missed?
I will start a new subject to see if I can get others to respond and help me figure this out, but thank you for your help.
