Solved by johnsonshiue. Go to Solution.
Solved by gsn_jp. Go to Solution.
To be certain you have incorporated edits to all geometry in a part file, use Rebuild All. Autodesk Inventor regenerates the entire file, even if some geometry did not require an update.
You must be working in a part file:
By contrast, the Update command regenerates only the geometry that has significant edits held in memory. If the Defer Update option is selected (on Assembly tab of the Application Options dialog box), you can continue working without incorporating edits to geometry until you click Update.
Hi! There is indeed a command in Inventor like AutoCAD REGEN. It is call Refine Appearance. To enable the command, you need to check "Disable automatic refinement" in Application Options. See below posting.
When the option is checked, Inventor will not automatically regenerate graphics. So, a circle can look like a polygon. The benefit is the graphical performance. In order to refine the graphics (regenerate), simply click Refine Appearance button at QAT at the top or View -> Refine Appearance.
Many thanks!
