Inventor General Discussion
Member
stugib82
Message 1 of 10 (292 Views)
Reference Parts
292 Views, 9 Replies
09-24-2012 04:42 AM
Hi.
Can anyone help me??
I'm having trouble showing a reference part in an assembly drawing. When said part is set to "reference" it is no longer visible on the drawing. Does anyone know why this could be?
Any help would be greatly appreciated.
mrattray
Message 2 of 10 (288 Views)
Re: Reference Parts
09-24-2012 04:55 AM in reply to: stugib82
Check the view settings. They should look like mine if you want them to appear like normal parts.
Mike (not Matt) Rattray
Member
stugib82
Message 3 of 10 (283 Views)
Re: Reference Parts
09-24-2012 05:43 AM in reply to: mrattray
Hi.
Thanks for your help and have adjusted my settings but it doesn't seemed to have helped.
Any other suggestions?
mrattray
Message 4 of 10 (276 Views)
Re: Reference Parts
09-24-2012 06:00 AM in reply to: stugib82
Can you attach the data set here, or supply pictures of what you're seeing?
Distinguished Mentor
john.retzlaff
Message 5 of 10 (273 Views)
Re: Reference Parts
09-24-2012 06:04 AM in reply to: stugib82
Are you sure the visibility of the part is turned on in the assembly?
If the view was created with the visibility of the part off, then turn visibility on and make the view associative.
John Retzlaff
Employee
johnsonshiue
Message 6 of 10 (252 Views)
Re: Reference Parts
09-24-2012 09:39 AM in reply to: stugib82
Hi! Could you post an example of the problem you are seeing here or send the files to me? The behavior does not sound right to me.
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
Member
stugib82
Message 7 of 10 (218 Views)
Re: Reference Parts
09-24-2012 11:21 PM in reply to: johnsonshiue
It's not possible to show what I am seeing at the moment. The part is visible in the drawing when it is set as a default part but when I change it to reference it disappears from the view.
*Pro
sbixler
Message 8 of 10 (194 Views)
Re: Reference Parts
09-25-2012 03:55 AM in reply to: stugib82
Is the reference part at some distance from the rest of the parts in the view?  Reference parts are not taken into account when calculating the extents of the view, so the view is essentially cropped around the "real" parts.  You can adjust this view margin in the Edit View box, Model State tab.  The margin shown is what Inventor calculated, but you can increase it in order to pick up reference parts that may be partially or totally left out of the view.
Don't know if that's what's happening in your case, though, since you haven't posted any images or files.
mrattray
Message 9 of 10 (190 Views)
Re: Reference Parts
09-25-2012 04:21 AM in reply to: stugib82
If you want a solution then you need to show us something, otherwise we're just shooting into the dark.
Why can't you show us? If it's confidentiality issues, make up a model and drawing that exhibits the same behaviour.
Member
stugib82
Message 10 of 10 (187 Views)
Re: Reference Parts
09-25-2012 04:24 AM in reply to: mrattray
I'm not currently at work and won't be back until Thursday. Will try and get something sent then. I appreciate the help. Sent from my iPhone
